LPG VIALLE
- vali
29 März 2011 17:39 #1
von vali
LPG VIALLE wurde erstellt von vali
Hi ! I need some help.
Is there a way to start the engine directly on lpg ?
My fuel pump is dead. The car is a Saab 93, 2001, on a VIALLE lpi .
- klappstuhl
30 März 2011 06:22 #2
von klappstuhl
klappstuhl antwortete auf Aw: LPG VIALLE
vali schrieb:
hi too,
no,there is no way that i know. the switsh at the LPI from gasoline to LPG is controled by the temperatur in the LPG-control-unit.
there is no direct-start-option like other LPG-companies use it. i think you have to repair your fuelpump. excuse my terrible english and
goog luck
hi too,
goog luck
- vali
30 März 2011 06:50 #3
von vali
vali antwortete auf Aw: LPG VIALLE
ohh bloody hell !
Why didnt they do an emergency lpg start ? damn !
The thing is that i'm miles away from home, the car is in a parking lot.
- klappstuhl
30 März 2011 08:46 #4
von klappstuhl
vali schrieb:
are you sure that the fuelpump is broken? have you checked the fuse of it?
is there enough elektrik energie at the pump?
you can also try to give it some hits when someone else start the engine(i think the pump is under the backseats). it could be that it starts a last time.
ohh bloody hell !
- vali
30 März 2011 14:12 #5
von vali
The fuel pump was doomed. The electric motor was dead.
I purchased a second hand one, 35 dollars, and i'm back online. I did broke a few plastic tabs but when i get home, i shall fix them.
Thanks for advices !
Ladezeit der Seite: 0.228 Sekunden
